Creating a Crowd Counting Rule
If you are using the Next-Gen engine, you can use cameras that your administrator configured as Crowd Counting cameras to create a rule.
When you select a Crowd Counting camera, you will see the Count filter only. No other filters are available except for the Area filter.
