BriefCam User Guide
Adding Measures
Last Updated: 27 minute read
Version2025r1
LanguageEnglish
Measures are the results of calculations (these are often aggregates, such as sum, count, or average).
  • Click Edit sheet Edit sheet icon to see the Master items.
See also: Creating a Customized Dimension or Measure
The following table provides a brief description of each of the measures available:
Measure Name
Description
Sample Values
# of Bicycles
Total count of objects identified as bicycles
104, 50
# of Bicycles in Custom Dimensions
Total count of objects identified as bicycles within the custom dimensions, areas, paths or line crossing. An object can be counted in more than one area/path/line crossing.
104, 50
# of Bicycles in Specific Source
Total count of objects identified as bicycles in a specific source.
104, 50
# of Bicycles in Specific Source and Custom Dimensions
Total count of objects identified as bicycles in a specific source and path, area or line crossing.
To use this measure, unlink the measure as detailed in the Setting a Specific Source and Custom Dimension section.
104, 50
# of Bounced Visitors
The number of unique visitors to a particular Source Group who navigate away from the site after less than 1 minute (by default) within the same day (by default).
To change the defaults, unlink the measure as defined in the Changing a Default Value in Visitors Measures section.
Available in Detailed dashboards only.
# of Bounced Visitors in Custom Dimensions
The number of unique visitors to a particular Source Group with a custom dimension (area, path, or line crossing) who navigate away from the site after less than 1 minute (by default) within the same day (by default).
# of Bounced Visitors in Specific Source, Source Group and Custom Dimensions
The number of unique visitors in a specific source, source group and custom dimension (path, area or line crossing), who navigate away from the site after less than 1 minute (by default) within the same day (by default).
# of Custom Class Objects
Number of detected objects per Custom Class
# of Custom Class Objects per Specific Custom Dimension
Number of detected objects per Custom Class and Custom Dimension
# of Custom Class Objects per Specific Source
Number of detected objects per Custom Class and Source
# of Custom Class Objects per Specific Source and Custom Dimension
Number of detected objects per Custom Class, Source and Custom Dimension
# of Illumination Changes
Total count of objects identified as illumination changes (Lights on, Lights off)
104, 50
# of Illumination Changes in Area
Total count of objects identified as illumination changes within the custom dimension, area. An object can be counted in more than one area.
104, 50
# of Illumination Changes in Specific Source
Total count of objects identified as illumination changes in a specific source.
104, 50
# of Illumination Changes in Specific Source and Area
Total count of objects identified as illumination changes in a specific source and area.
This measure is used, for example, to count the number of illumination changes in the same sheet.
104, 50
# of License Plates
Total count of objects identified by license plates.
104, 50
# of License Plates in Custom Dimensions
Total count of objects identified by license plates within the custom dimensions, areas, paths or line crossing. An object can be counted in more than one area/path/line crossing.
104, 50
# of License Plates in Specific Site, Source and Custom Dimensions
Total count of objects identified as license plates in a specific site, source and path, area or line crossing.
104,50
# of License Plates in Specific Source
Total count of objects identified by license plates in a specific source.
104, 50
# of License Plates in Specific Source and Custom Dimensions
Total count of objects identified as license plates in a specific source and path, area or line crossing.
104, 50
# of New Unique Identities
Total count of new identities with a unique face ID. These identities will be counted only when they are first detected on the cameras.
# of Objects
Total count of objects.
104, 50
# of Objects in Custom Dimensions
Total count of objects within the custom dimensions, areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
104, 50
# of Objects in Specific Source
Total count of objects in a specific source.
This measure is used, for example, to count objects from different sources in the same sheet.
104, 50
# of Objects in Specific Source and Custom Dimensions
Total count of objects in a specific source and path, area or line crossing.
This measure is used, for example, to count the number of objects in different areas in the same sheet.
104, 50
# of People
Total count of objects identified as people (Man, Woman, Child)
104, 50
# of People in Custom Dimensions
Total count of objects identified as people within the custom dimensions, areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
104, 50
# of People in Specific Source
Total count of objects identified as people in a specific source.
104, 50
# of People in Specific Source and Custom Dimensions
Total count of objects identified as people in a specific source and path, area or line crossing.
This measure is used, for example, to count the number of people in different areas in the same sheet.
104, 50
# of People Not Wearing Face Mask
Total count of objects identified as people not wearing a face mask.
# of People Not Wearing Face Mask in Custom Dimensions
Total count of objects identified as people not wearing a face mask within the custom dimensions (areas, paths or line crossings).
# of People Not Wearing Face Mask in Specific Source
Total count of objects identified as people not wearing a face mask in a specific source.
# of People Not Wearing Face Mask in Specific Source and Custom Dimensions
Total count of objects identified as people not wearing a face mask in a specific source and path, area or line crossing.
# of People Wearing Face Mask
Total count of objects identified as people wearing a face mask.
# of People Wearing Face Mask in Custom Dimensions
Total count of objects identified as people wearing a face mask within the custom dimensions (areas, paths or line crossings).
# of People Wearing Face Mask in Specific Site, Source and Custom Dimensions
Total count of objects identified as people wearing a mask in a specific site, source and path, area or line crossing.
# of People Wearing Face Mask in Specific Source
Total count of objects identified as people wearing a face mask in a specific source.
# of People Wearing Face Mask in Specific Source and Custom Dimensions
Total count of objects identified as people wearing a mask in a specific source and path, area or line crossing.
# of People with Backpack
Total count of objects identified as people holding a backpack. This measure is available for aggregated dashboards only.
# of People with Handheld Bag
Total count of objects identified as people holding a bag
# of People with Handheld Bag in Custom Dimensions
Total count of objects identified as people holding a bag within the custom dimensions (areas, paths or line crossings).
# of People with Handheld Bag in Specific Source
Total count of objects identified as people holding a bag in a specific source.
# of People with Handheld Bag in Specific Source and Custom Dimensions
Total count of objects identified as holding a bag in a specific source and path, area or line crossing.
# of People without Handheld Bag
Total count of objects identified as people not holding a bag. This measure is available for aggregated dashboards only.
# of Returning Unique Identities
Total count of returning identities with a unique face ID.
# of Road Vehicles
Total count of objects identified as road vehicles (Motorcycle, Car, Pickup Truck, Van, Truck, Bus)
104, 50
# of Road Vehicles in Custom Dimensions
Total count of objects identified as road vehicles within the custom dimensions: areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
104, 50
# of Road Vehicles in Specific Site, Source and Custom Dimensions
Total count of objects identified as road vehicles in a specific site, source and path, area or line crossing.
104, 50
# of Road Vehicles in Specific Source
Total count of objects identified as road vehicles in a specific source.
104, 50
# of Road Vehicles in Specific Source and Custom Dimensions
Total count of objects identified as road vehicles in a specific source and path, area or line crossing.
104, 50
# of Speeding Road Vehicles
Total count of objects identified as road vehicles (Motorcycle, Car, Pickup Truck, Van, Truck, Bus) whose speed exceeds the speed specified on the Speed Limit Slider (available in the visualization folder)
104, 50
# of Unique Identities
Total count of identities with a unique face ID.
# of Unique Identities in Custom Dimensions
Total count of identities with a unique face ID within the custom dimensions: areas, paths or line crossings.
# of Unique Identities in Specific Site, Source, Source Group and Custom Dimensions
Total count of identities with a unique face ID in a specific site, source, source group and path, area or line crossing.
# of Unique Identities in Specific Source, Source Group and Custom Dimensions
Total count of identities with a unique face ID in a specific source, source group and path, area or line crossing.
# of Unique Identities on a Specific Route
Total count of identities that appeared in specific sources (in no particular order).
To use this measure:
  1. Drag the measure to the sheet.
  2. Unlink the visualization by right-clicking on the filter, selecting Unlink visualization and clicking OK.
  3. Go to the Actions menu’s Value field and click the expression icon (Expression icon.png).
  4. Uncomment the expression for the relevant use case (by removing the two slashes before the row) and comment out the default.
  5. Replace the text ‘SourceExample[1-3]’ with the name of your sources.
Note that an asterisk (*) in the expression stands for plus and the hyphen (-) stands for minus.
Avg # of New Unique Identities
Average count of new identities with a unique face ID.
Avg # of Objects
Average object count (per day)
104, 50
Avg # of Objects in Custom Dimensions
Average object count (per day) within the custom dimensions: areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
104, 50
Avg # of Objects in Custom Dimensions by Hour
Average object count (per hour) within the custom dimensions: areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
104, 50
Avg # of Objects in Specific Site, Source and Custom Dimensions
Average object count (per day) within the site, custom dimensions, areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
This measure provides the average object counts in different areas/paths/line crossings in the same sheet.
104, 50
Avg # of Objects in Specific Source
Average object count (per day) in a specific source.
This measure provides the average object count from different sources in the same sheet.
104, 50
Avg # of Objects in Specific Source and Custom Dimensions
Average object count (per day) within the custom dimensions, areas, paths or line crossings. An object can be counted in more than one area/path/line crossing.
104, 50
Avg # of Proximity Violation Contacts
Average number of people who have passed the proximity threshold with the selected person.
Note that the Proximity feature in the RESEARCH module is disabled by default. To enable this feature, contact your system administrator.
104, 50
Avg # of Proximity Violation Contacts in Specific Site and Source
Average number of people who have passed the proximity threshold with the selected person in a specific site and source.
This measure provides the average count of proximity threshold violations from different sources in the same sheet.
104, 50
Avg # of Proximity Violation Contacts in Specific Source
Average number of people who have passed the proximity threshold with the selected person in a specific source.
104, 50
Avg # of Returning Unique Identities
Average count of returning identities with a unique face ID.
Avg # of Unique Identities in Custom Dimensions
Average count of identities with a unique face ID (per day) within the custom dimensions: areas, paths or line crossings.
Avg # of Unique Identities in Custom Dimensions by Hour
Average count of identities with a unique face ID (per hour) within the custom dimensions: areas, paths or line crossings.
Avg # of Unique Identities in Specific Site, Source, Source Group and Custom Dimensions
Average count of identities with a unique face ID (per day) within a specific site, source, source group and custom dimensions (areas, paths or line crossings).
Avg # of Unique Identities in Specific Source, Source Group and Custom Dimensions
Average count of identities with a unique face ID (per day) within specific source, source group and custom dimensions (areas, paths or line crossings).
Avg Crowd Counting
Average size of crowd counted. This measure is available for aggregated dashboards only. Since version: 2024 R2
Avg Crowd Counting in Custom Dimensions
Average size of crowd counted within a specific custom dimension (areas, path, or line crossings). This measure is available for aggregated dashboards only. Since version: 2024 R2
Avg Detection Duration of Custom Class objects in Specific Custom Dimension
Detection duration per Custom Class and Custom Dimension (across objects, per hour: maximum of 60 minutes, minimum of 0 minutes)
Relevant for Aggregated dashboards only.
Avg Duration
Average object duration in seconds
0:00:14
Avg Duration Bicycles
Average duration in seconds of objects identified as bicycles
0:00:14
Avg Duration in Custom Dimensions
Average duration in seconds of objects within the custom dimensions: areas, paths or line crossings
0:00:14
Avg Duration in Specific Site, Source and Custom Dimensions
Average object duration time in seconds of objects within a specific site, source and custom dimensions (areas, paths or line crossings).
This measure provides the average duration of different areas/path in the same sheet.
0:00:14
Avg Duration in Specific Source
Average duration in seconds of objects within a specific source.
This measure provides the average duration of different Sources in the same sheet.
0:00:14
Avg Duration in Specific Source and Custom Dimensions
Average object duration time in seconds of objects within the custom dimensions: areas, paths or line crossings.
0:00:14
Avg Duration License Plates
Average duration in seconds of objects with detected license plates
0:00:14
Avg Duration of Custom Class Objects
Average duration per Custom Class
Avg Duration People
Average duration in seconds of objects identified as people (Man, Woman, Child)
0:00:14
Avg Duration Road Vehicles
Average duration in seconds of objects identified as road vehicles (Motorcycle, Car, Pickup Truck, Van, Truck, Bus)
0:00:14
Avg Max Proximity
Average maximum distance that a person had with other people for a certain amount of time.
5.25, 6.40
Avg Max Proximity in Specific Site and Source
Average maximum distance that a person had with other people for a certain amount of time in a specific site and source.
5.25, 6.40
Avg Max Proximity in Specific Source
Average maximum distance that a person had with other people for a certain amount of time in a specific source.
5.25, 6.40
Avg Min Proximity
Average minimum distance (in meters) that a person had with other people for a certain amount of time.
3.16, 4.70
Avg Min Proximity in Specific Site and Source
Average minimum distance (in meters) that had a person had with other people for a certain amount of time in a specific site and source.
3.16, 4.70
Avg Min Proximity in Specific Source
Average minimum distance (in meters) that had a person had with other people for a certain amount of time in a specific source.
3.16, 4.70
Avg Size
Average size per object in meters or feet (as per account settings)
1.8, 0.5
Avg Speed
Average speed per object in km/hour
0:00:14
Avg Visit Duration Unique Identities
The average visit duration time of identities with a unique face ID, calculated within the same day (by default), across cameras within the same Source Group.
The duration time is calculated by taking the person’s latest appearance time and subtracting by the first appearance time.
To change the defaults, unlink the measure as defined in theChanging a Default Value in Visitors Measures section.
Avg Visit Duration Unique Identities in Custom Dimensions
The average visit duration time of identities with a unique face ID, calculated within the same day (by default), across cameras within the same Source Group and within the custom dimensions (areas, paths or line crossings).
Avg Visit Duration Unique Identities in Specific Site, Source, Source Group and Custom Dimensions
The average visit duration time of identities with a unique face ID, calculated within the same day (by default), across cameras within a specific site and source in the same Source Group and within the custom dimensions (areas, paths or line crossings).
Avg Visit Duration Unique Identities in Specific Source, Source Group and Custom Dimensions
The average visit duration time of identities with a unique face ID, calculated within the same day (by default), across cameras within a specific source in the same Source Group and within the custom dimensions (areas, paths or line crossings).
Max # of New Unique Identities
Maximum count of new identities with a unique face ID.
Max # of Returning Unique Identities
Maximum count of returning identities with a unique face ID.
Max Avg Visit Duration Unique Identities
The maximum visit duration time of identities with a unique face ID, calculated within the same day (by default).
Max Bicycles/Hour
Maximum count of objects per hour, identified as bicycles
15
Max Crowd Counting/Hour
Maximum size of a crowd per hour. This measure is available for aggregated dashboards only.
Max Crowd Counting/Hour in Custom Dimensions
Maximum size of a crowd per hour within a custom dimension (areas, paths, and line crossings). This measure is available for aggregated dashboards only.
Max Illumination Changes/Hour
Maximum count of illumination changes per hour
15
Max License Plates/Hour
Maximum count of license plates per hour
15
Max Objects/Hour
15
Max Objects/Hour in Custom Dimensions
Maximum count of objects within the custom dimensions: areas, paths or line crossings, per hour
15
Max Objects/Hour in Specific Source
Maximum count of objects in a specific source, per hour.
This measure is used, for example, to present the maximum number of objects per hour in different sources in the same sheet.
15
Max Objects/Hour in Specific Source and Custom Dimensions
Maximum count of objects in a specific source within the custom dimensions: areas, paths or line crossings, per hour.
This measure is used, for example, to present the maximum number of objects in a specific source per hour of different areas/paths/line crossings in the same sheet.
15
Max People/Hour
Maximum count of objects identified as people (Man, Woman, Child), per hour. People counting has its own measure for this functionality.
Max People Not Wearing Face Mask/Hour
Maximum count of objects identified as people not wearing a face mask, per hour.
Max People Wearing Face Mask/Hour
Maximum count of objects identified as people wearing a face mask, per hour.
Max Road Vehicles/Hour
Maximum count of objects identified as road vehicles (Motorcycle, Car, Pickup Truck, Van, Truck, Bus), per hour
15
Max Unique Identities/Hour
Maximum count of identities with a unique face ID per hour
Max Unique Identities/Hour in Custom Dimensions
Maximum count of identities with a unique face ID within the custom dimensions (areas, paths or line crossings), per hour
Max Unique Identities/Hour in Specific Source, Source Group and Custom Dimensions
Maximum count of identities with a unique face ID in a specific source and source group within the custom dimensions (areas, paths or line crossings), per hour.
This measure is used, for example, to present the maximum number of face IDs in a specific source per hour of different areas/paths/line crossings in the same sheet.
Note
People Counting has separate filters, dimensions and measures. People Counting data will not be seen together with other objects’ data. For example, if you filter on a specific date it will not affect the data of the people counting.
People Counting: Avg # of People
Average people count (per day)
104, 50
People Counting: Avg # of People in Area
Average people count (per day) within the custom area dimensions. A person can be counted in more than one area.
104, 50
People Counting: Avg # of People in Specific Source
Average people count (per day) in a specific source.
This measure provides the average people count from different sources in the same sheet.
104, 50
People Counting: Avg # of People in Specific Source and Area
Average people count (per day) in a specific source within the custom area dimension. An object can be counted in more than one area.
This measure provides the average object counts in different areas in the same sheet.
104, 50
People Counting: Max # of People/Hour
Calculates the average # of people per hour and then finds the maximum value.
This measure is used, for example, to present the maximum number of people per hour in the same sheet.
15
People Counting: Max # of People/Hour in Area
Calculates the average # of people per hour within the custom area dimensions and then finds the maximum value.
This measure is used, for example, to present the maximum number of people per hour of different areas in the same sheet.
15
People Counting: Max # of People/Hour in Specific Source
Calculates the average # of people per hour in a specific source and then finds the maximum value.
This measure is used, for example, to present the maximum number of people per hour in different sources in the same sheet.
15
People Counting: Max # of People/Hour in Specific Source and Area
Calculates the average # of people per hour in a specific source within the custom area dimensions and then finds the maximum value.
This measure is used, for example, to present the maximum number of people in a specific source per hour of different areas in the same sheet.
15
Visitors Bounce Rate
The percentage of bounced visitors (see # of Bounced Visitors measure) out of the number of unique identities (see # of Unique Identities measure) within the same day (by default).
Visitors Bounce Rate in Custom Dimensions
The percentage of bounced visitors within custom dimensions (see # of Bounced Visitors in Custom Dimensions measure) out of the number of unique identities (see # of Unique Identities in Custom Dimensions measure) within the same day (by default).
Visitors Bounce Rate in Specific Source, Source Group and Custom Dimensions
The percentage of bounced visitors within specific source, source group and custom dimensions (see # of Bounced Visitors in Specific Source, Source Group and Custom Dimensions measure) out of the number of unique identities (see # of Unique Identities in Specific Source, Source Group and Custom Dimensions measure) within the same day (by default).
