BriefCam User Guide
Adding Dimensions
Last Updated: 7 minute read
Version2025 R1
LanguageEnglish
Dimensions determine how the data in a visualization are grouped (this often refers to time, class, etc.).
  • Click Edit sheet Edit sheet icon to see the Master items.
See also: Creating a Customized Dimension or Measure
The table below provides a brief description of each of the dimensions available:
Dimension Name
Description
Sample values
1‑min. Intervals
Groups of the data in 1-minute time intervals
Available in Detailed dashboards only.
02:10, 02:11, 02:12
5‑min. Intervals
Groups of the data in 5-minute time intervals
04:10, 04:15, 04:20
10‑min. Intervals
Groups of the data in 10-minute time intervals. People counting has its own dimension for this functionality.
03:10, 03:20, 03:30
15‑min. Intervals
Groups of the data in 15-minute time intervals. People counting has its own dimension for this functionality.
05:00, 05:15, 05:30
30‑min. Intervals
Groups of the data in 30-minute time intervals. People counting has its own dimension for this functionality.
04:00, 04:30, 05:00
Class
Object class
Man, Woman, Car, Truck
Class (People)
Only “People” object classes, meaning: Man, Woman and Child
Man, Woman, Child
Class (Road Vehicles)
Only “Road Vehicles” object classes, meaning: Motorcycle, Car, Pickup Truck, Van, Truck, Bus
Class Category
Contains the following class categories:
  • People: Man, Woman, Child
  • Bicycles: Bicycle
  • Road Vehicles: Motorcycle, Car, Pickup Truck, Van, Truck, Bus
  • Other Vehicles: Train, Airplane, Boat
  • Illumination Changes: Lights On, Lights Off
  • Animals: Animals
People, Bicycles, Road Vehicles, Other Vehicles, Animals
Color
Object main color
Black, Green, Orange
Custom Class
Custom class name
Custom Dimensions
Custom dimension name (as configured in the Sources module). This includes the Path, Area, and Line Crossing filters. For people counting, use the People Counting: Area dimension.
Shoes, Accessories, North, East
Date
Object date. People counting has its own dimension for this functionality.
19/03/2018
Date Time
Object date time. People counting has its own dimension for this functionality.
19/03/2018 13:03
Day
Object day. People counting has its own dimension for this functionality.
Mon, Tue, Wed
Day (Num)
Object day number (for example, 19 if the date is 19/03/2018). People counting has its own dimension for this functionality.
1,2,15,17,19
Direction
Object direction in degrees
18º, 45º
Direction Label
Object general direction:
  • Up: 0º<direction<45º or 315º<direction<360º
  • Right: 45º<=direction<=135º
  • Down: 135º<direction<225º
  • Left: 225º<=direction<=315º
Up, Right, Down, Left
Duration
Object duration in seconds, calculated as the difference between Object start time and Object end time in the frame
0:00:02
Dwell (Sec)
Objects having dwelled for a user-specified period of time or more, in seconds
11, 21
Face Mask
Object’s Face Mask classification: Mask, No Mask or Unknown.
Mask, No Mask, Unknown
Handheld Bag
Object’s Handheld classification: Handheld Bag, No Handheld Bag or Unknown
Hour
Object time in hour range format. People counting has its own dimension for this functionality.
04:00-05:00, 21:00-22:00
Hour (hh)
Object time in hour format. People counting has its own dimension for this functionality.
06:00
Hour (Num)
Object time in hour number format. People counting has its own dimension for this functionality.
16, 21
License Plates
Objects detected as license plates
6DN3168, 1049189
Make
Object's vehicle make
Make & Model Drill Down
Drill down from vehicle to make to model.
Note that all cars may not have Make & Model in the RESEARCH module. This is because Make & Model is only presented when the Make and the Model are consistent with each other. If the engine generates a Make & Model that is inconsistent (such as Honda Highlander) it will not be saved into the database.
Model
Object’s vehicle model
Month
Object time in month format. People counting has its own dimension for this functionality.
Mar, Apr
Month (Num)
Object time in month number format. People counting has its own dimension for this functionality.
3, 4
Object End Time
19/03/2018 13:04:11
Object Start Time
Object start time in the frame
19/03/2018 13:00:02
People Counting has separate filters, dimensions and measures. People Counting data will not be seen together with other objects’ data. For example, if you filter on a specific date it will not affect the data of the people counting.
People Counting: 10‑min. Intervals
Groups of the data in 10-minute time intervals for people counting
03:10, 03:20, 03:30
People Counting: 15‑min. Intervals
Groups of the data in 15-minute time intervals for people counting
05:00, 05:15, 05:30
People Counting: 30‑min. Intervals
Groups of the data in 30-minute time intervals for people counting
04:00, 04:30, 05:00
Custom area dimension name (as configured in the Sources module) for people counting
People Counting: Date
Date that people were counted
19/03/2018
People Counting: Date Time
Date and time that people were counted
19/03/2018 13:03
People Counting: Day
Day of the week that people were counted
Mon, Tue, Wed
People Counting: Day (Num)
Number of the day that people were counted (for example, 19 if the date is 19/03/2018)
1,2,15,17,19
People Counting: Hour
Time, in hour range format, that people were counted
People Counting: Hour (hh)
Time, in hour format, that people were counted
06:00
People Counting: Hour (Num)
Time, in hour number format, that people were counted
16, 21
People Counting: Month
Time, in month format, that people were counted
Mar, Apr
People Counting: Month (Num)
Time, in month number format, that people were counted
3, 4
People Counting: Source
Source name (as configured in the Sources tab) for people counting
Airport, Floor A
People Counting: Time Drill Down-Time
Time drill down within object visualization for people counting, according to: Date, Hour, 30-min, 10-min
People Counting: Week #
Time, in week number format, that people were counted
9, 14, 20
Size
Object size in meters or feet (as per account settings)
1.8, 0.5
Source
Source name (as configured in the Sources tab). People counting has its own dimension for this functionality.
Airport, Floor A
Source Group
Source Group name (as configured in the Source Group tab). Only groups that are active in the UI will appear.
First floor, ATM machines
Source Group Watchlist
The name of the external watchlists associated with a Source Group.
VIPs, Employees
Speed
Object speed in km/hour or miles/hour (as per account settings)
10, 78, 111
Time Drill Down
Time drill down within object visualization, according to: Date, Hour, 30-min, 10-min, 5-min, 1-min. People counting has its own dimension for this functionality.
Tolerance
This dimension is currently not supported.
Allows users to select the threshold of the object quality included in the dashboard. The threshold impacts the detection sensitivity: Loose, Normal, Strict. For example, Loose tolerance might include in the dashboard, items that are not detected as objects, such as shadows and lighting.
Note that this dimension does not affect the tolerance of the Custom Dimensions, which can be set when editing the Custom Dimension and will be applicable from the time it was set.
Watchlist Identity
The identity name within a watchlist. This is only available if this face is related to an external watchlist.
Sam, Margaret
Week #
Object time in week number format. People counting has its own dimension for this functionality.
9, 14, 20
