BriefCam User Guide
Common Paths Visual Layer
Version2024r2
LanguageEnglish
To generate a common path heat map:
  1. Click the Visual Layers control (Visual layers icon.png).
  2. Click the Common Paths icon (Common paths icon.png) to display a common paths layer, which highlights the paths most commonly taken by objects detected in the video (see below).
The common paths legend (Common paths legend.png) available at the bottom of the synopsis playback window indicates the number of detected events having followed the paths indicated via the different colors.
