BriefCam User Guide
Activity Heat Map
Version2024r2
LanguageEnglish
To generate an activity heat map:
  1. Click the Visual Layers control (Visual layers icon.png).
  2. Click the Activity icon (Activity icon.png) to display an activity heat map layer, which highlights areas in which increased event movement has been detected (see below).
The activity heat map legend (Activity map legend.png) available at the bottom of the synopsis playback window indicates the number of detected objects associated with each of the various heat map colors.
