BriefCam Troubleshooting Guide
When accessing RESEARCH dashboards, why am I receiving a 400 error page with the error message "incorrect header"?
Version2025r1
LanguageEnglish
From your workstation:
  1. From the BriefCam Administrator Console, go to Settings > Environment Settings.
  2. Verify that the QlikServer setting contains the correct IP address/hostname/FQDN for the Server running RESEARCH.
On the server running RESEARCH:
  1. Open a browser as the BCUser (or the applicative user you are using) on the server that runs research (right click on the browser icon and select “Run as a different user”).
  2. Browse to https://localhost/qmc.
  3. Browse to virtual proxies on the bottom left.
  4. Double click BC.
  5. On the right-hand side, click Advanced.
  6. Add a new value in the host allow list.
  7. Add the host IP address/hostname/FQDN.
