BriefCam Troubleshooting Guide
Why is the BriefCam tab missing from the Milestone XProtect embedded client?
Version2024r2
LanguageEnglish
Symptom
The BriefCam tab is missing from the Milestone XProtect embedded client.
Possible Root Causes
  • Visual Studio X64 redistributable package is not installed. This can be caused by a GPO or other restrictions applied by the System Administrator.
  • Windows is not up to date (even though this is one of the prerequisites).
Solution
  1. On the Smart Client machine, download the following: https://aka.ms/vs/17/release/vc_redist.x64.exe.
  2. Run the executable file as Admin.
  3. Clear the cache on the Milestone Smart client side:
    1. Go to: C:\Users\CurrentLoggedInUser \AppData\Roaming\Milestone\BriefCam\MilestoneEmbedded.
      Note that the AppData folder is a hidden folder. If you do not have hidden folders enabled on your machine, you can open the AppData folder by going to the search bar on your Windows Toolbar, typing %appdata% and pressing Enter.
    2. Delete all the contents of this folder. On the next Milestone XProtect client startup, the contents of this folder will be re-created.
    3. Access the Milestone XProtect embedded client.
  4. If this does not work, install the latest Windows update.
