BriefCam Troubleshooting Guide
Why does an object disappear?
Version2024r2
LanguageEnglish
Sometimes, when different objects presented at the same time collide, the rendering engine hides one of them to prevent on-screen clutter. Even if an object disappears it still exists in the database and can be seen in the original video. You may also try to reduce the density control to show less concurrent objects.
