BriefCam Troubleshooting Guide
The processing fails and in the log I’m getting the error: Failed to reserve memory for DeviceBuffer. What should I do?
Version2024r2
LanguageEnglish
If the processing (Processing Server service / Alert Processing Server service) fails, you may see something like the following in the logs:
"ERROR - Throw: Failed to reserve memory for DeviceBuffer"
To resolve this issue, set the OX.ini file’s FrameTimeoutMS parameter to 3000000.
