Converting an Existing BriefCam Environment into a Site
As of BriefCam 2024 M1 HF1, if you want to convert an existing BriefCam environment into a Site:
Download the
update_sideid_for_research.batscript from the BriefCam Downloads page.Save the script to the same location where the
SetLogFileName.batfile is saved.Run the
update_siteid_for_research.batscript as the BriefCam user (by default:bcuser).Make sure the Site.Id environment setting is set with a valid URL. Remember that the site registration is done on the Hub. For additional information, see the Registering a Site on the Hub section.)
Once this is done, pre-existing rules and sources will be sent to the Hub.
