BriefCam Installation Guide
Silent Installations
Last Updated: 3 minute read
Version2024r2
LanguageEnglish
Silent installations are available for several installers: PostgreSQL, Server, Web Services, RESEARCH, MongoDB and RabbitMQ.
To use the silent installations:
  1. Sign into the machine using an administrator account.
  2. Open PowerShell.
  3. Run the silent install commands listed below for each one of the components.
    1. Select the relevant PowerShell command according to the type of user you want to run BriefCam’s services (local user or domain user)
    2. Fill out all the relevant parameters and pay special attention to SERVER_DOMAIN and SERVER_USER – These parameters must be case sensitive.
Note that:
  • In the commands below, you can change the APPDIR parameter to: "C:\Program Files\Briefcam" instead of using the env variable.
  • Special characters are not supported for passwords.
PostgreSQL Installer
{ PostgresInstaller file name} /qn BC_DOMAIN="." BC_USER="{user to run BriefCam services}" BC_PWD="{BriefCam's user password}" DENY_USER_REMOTE_LOGIN="{true/false}" CREATE_BC_USER="NO" APPDIR="$env:ProgramFiles\briefcam\Briefcam PostgreSQL " DB_INSTALLDIR=C:\PostgreSQL POSTGRESQL_DATA_DIR="C:\PostgreSQL_Data" BRIEFCAM_SHARED_FOLDER="{BriefCam required shared folder}" POSTGRES_PORT=5432 POSTGRES_ADMIN_USER="dbadmin" POSTGRES_ADMIN_PASSWORD="{db admin password}" POSTGRES_BC_USER="{DB user for BriefCam user}" POSTGRES_BC_PASSWORD="{DB password for BriefCam user}" /l*v "C:\PostgreSQLInstaller.log
Server Installer
Local User
{ ServerInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam\BriefCam Server" NOTIFICATION_PORT=7080 VIDEOGATEWAY_PORT=5010 POSTGRES_ADDRESS="{BriefCam DB hostname}" POSTGRES_PORT=5432 POSTGRES_BC_USER="{DB user for BriefCam user}" POSTGRES_BC_PASSWORD="{DB password for BriefCam user}" SERVER_DOMAIN="." SERVER_USER="{user to run BriefCam services}" SERVER_PWD="{BriefCam's user password}" CREATE_SERVER_USER="NO" BC_SHARED_DATA_FOLDER="\\{server hostname}\BriefCam" PASSPHRASE="{optional passphrase}" IS_VIDEO_STREAMING="YES" /l*v "{logfolder}\log.log"
Domain User
{ ServerInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam\BriefCam Server" NOTIFICATION_PORT=7080 VIDEOGATEWAY_PORT=5010 POSTGRES_ADDRESS="{BriefCam DB hostname}" POSTGRES_PORT=5432 POSTGRES_BC_USER="{DB user for BriefCam user}" POSTGRES_BC_PASSWORD="{DB password for BriefCam user}" SERVER_DOMAIN="{domain name}" SERVER_USER="{user to run BriefCam services}" SERVER_PWD="{BriefCam's user password}" CREATE_SERVER_USER="NO" BC_SHARED_DATA_FOLDER="\\{server hostname}\BriefCam" PASSPHRASE="{optional passphrase}" IS_VIDEO_STREAMING="YES" /l*v "{logfolder}\log.log"
Web Services Installer
Local User
{ WebInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam" WS_HOST="$env:computername" WS_PORT=80 CREATE_SERVER_USER="NO" SERVER_DOMAIN="." WS_USER="{user to run BriefCam web services}" WS_PWD="BriefCam's user password}" POSTGRES_ADDRESS="{BriefCam DB hostname}" POSTGRES_PORT=5432 POSTGRES_BC_USER="{DB user for BriefCam user}" POSTGRES_BC_PASSWORD="{DB password for BriefCam user}" BRIEFCAM_SHARE="\\{server hostname}\BriefCam" LICENSE_SERVER_ADDR="{server hostname}" PASSPHRASE="{optional passphrase}" USAGE_DATA_SETTINGS="{true/false}" /l*v "{logfolder}\log.log"
Domain User
{ WebInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam" WS_HOST="$env:computername" WS_PORT=80 CREATE_SERVER_USER="NO" SERVER_DOMAIN="{domain name}" WS_USER="{user to run BriefCam web services}" WS_PWD="BriefCam's user password}" POSTGRES_ADDRESS="{BriefCam DB hostname}" POSTGRES_PORT=5432 POSTGRES_BC_USER="{DB user for BriefCam user}" POSTGRES_BC_PASSWORD="{DB password for BriefCam user}" BRIEFCAM_SHARE="\\{server hostname}\BriefCam" LICENSE_SERVER_ADDR="{server hostname}" PASSPHRASE="{optional passphrase}" USAGE_DATA_SETTINGS="{true/false}" /l*v "{logfolder}\log.log"
RESEARCH Installer
Silent Installation with Default Parameters
{ ResearchInstaller file name}
Silent Installation with Non-Default Parameters
{ ResearchInstaller file name} --SERVER_PORT "8090" --RESEARCH_ENDPOINT "{RESEARCH hostname or load balancer endpoint}" --POSTGRES_ADDRESS "{BriefCam DB hostname}" --POSTGRES_PORT "5432" --POSTGRES_BC_USER "{DB user for BriefCam user}" --POSTGRES_BC_PASSWORD "{DB password for BriefCam user}" --DOMAIN_NAME "." --BRIEFCAM_USER "{user to run BriefCam services}" --BRIEFCAM_USER_PWD "{BriefCam's user password} --QLIK_DATA_FOLDER "C:\QlikShare" --QLIK_BACKUP_FOLDER "C:\Program Files\BriefCam\qlikbackup"
Custom LEF License
{ ResearchInstaller file name} --SERVER_PORT "8090" --RESEARCH_ENDPOINT "{RESEARCH hostname or load balancer endpoint} --POSTGRES_ADDRESS "{BriefCam DB hostname}" --POSTGRES_PORT "5432" --POSTGRES_BC_USER "{DB user for BriefCam user}" --POSTGRES_BC_PASSWORD "{DB password for BriefCam user}" --QLIK_LICENSE_SERIAL "9721750115078957" --QLIK_LICENSE_CONTROL "10565" --QLIK_LICENSE_LEF "{Qlik license lef}`n`ANALYZER`;`20`;`;`n`GEOANALYTICS`;`YES`;`;`n`GEOPLUS`;`YES`;`;`n`IGNORE_TOKENS`;`YES`; `;`n`OVERAGE`;`NO`;`;`n`PRODUCTLEVEL`;`50`;`;`2023`-01`-20`n`PROFESSIONAL`;`4`;`;`n`SPECIAL_EDITION`;`NFR`;`;`n`SPECIAL_EDITION`;`OEM`;`;`n`TIMELIMIT`;`VALUE`;`;`2023`-01`-`21`n`WEBCONNECTORS`;`YES`;`;`n`4YK2`-PAQN`-NDSB`-7YN6`-L2JX" --DOMAIN_NAME "." --BRIEFCAM_USER "{user to run BriefCam services}" --BRIEFCAM_USER_PWD "{BriefCam's user password} --QLIK_DATA_FOLDER "C:\QlikShare" --QLIK_BACKUP_FOLDER "C:\Program Files\BriefCam\qlikbackup"
Distributed Installation
{ ResearchInstaller file name} --SERVER_PORT "8090" --RESEARCH_ENDPOINT "{RESEARCH hostname or load balancer endpoint} --POSTGRES_ADDRESS "{BriefCam DB hostname}" --POSTGRES_PORT "5432" --POSTGRES_BC_USER "{DB user for BriefCam user}" --POSTGRES_BC_PASSWORD "{DB password for BriefCam user}" --DOMAIN_NAME "." --BRIEFCAM_USER "{user to run BriefCam services}" --BRIEFCAM_USER_PWD "{BriefCam's user password} --QLIK_DATA_FOLDER "C:\QlikShare" --QLIK_BACKUP_FOLDER "C:\Program Files\BriefCam\qlikbackup"
MongoDB
{ MongoDBInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam" MONGODB_PORT=27017 POSTGRES_ADDRESS="{BriefCam DB hostname}" POSTGRES_PORT=5432
RabbitMQ
{ RabbitMQInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam" POSTGRES_ADDRESS="{BriefCam DB hostname}" POSTGRES_PORT=5432 POSTGRES_BC_USER="{DB user for BriefCam user}" POSTGRES_BC_USER_PASSWORD="{DB password for BriefCam user}"
VMS Plugins
Milestone Integration Plugin
To run a silent installation of the Milestone Plugin without SSO, use the following command line:
{ MilestoneInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam"
To run a silent installation of the Milestone Plugin with SSO, use the following command line:
{ MilestoneInstaller file name} /qn APPDIR="$env:ProgramFiles\briefcam" INSTALL_SSO_PROVIDER="YES" MILESTONE_VMS_ADDRESS="{ip/hostname}" SSO_PROVIDER_ADDRESS="{address url}"
See also:
Silent Installations for UpgradingSilent Installations for Upgrading
Silent Installation of Genetec Plugins (Genetec Integration)Genetec Integration
(Silent Installation of NiceVision PluginsSilent Installation of NiceVision Plugins
