Order of Installation
It is important to install the components in the following order, as there are dependencies between the different components. The sections below will describe each of the components.
The links to the installation files are available from the Installation Downloads page.
Database (
BriefCamPostgreSQL.exe) – This file installs the PostgreSQL database.RabbitMQ (
BriefCamRabbitMQ.exe)BriefCam Server (
BriefCamServer.exe)On the server machines, in addition to the Server component, you also need to install:
NVIDIA driver – For any Server machine with a GPU, use a supported version of the NVIDIA driver (see: BriefCam Supported Hardware and Software - v2024 R2). Note that you cannot put NVIDIA graphic cards from different models on the same machine. Make sure to restart the machine after installing the NVIDIA driver.
BriefCam RESEARCH (
BriefCamRESEARCH.exe) – Run this file only if you will be using the RESEARCH solution.Upgrade to Qlik November 2025 - It is highly recommended to upgrade to Qlik version (November 2025), bringing the newest security patches and improved stability.
Create Virtual Proxy (optional)
BriefCam Web Services (
BriefCamWebServices.exe)BriefCam VMS integration plugins – Install the plugin for your VMS on every Server machine.
Help Center Installation (
BriefCamHelpCenter.exe) – Run this file only if BriefCam will be run offline.
Note
When installing or upgrading BriefCam or upgrading the NVIDIA GPU driver, it takes up to 30 minutes for the Processing Server service or Alert Processing Server service to start for the first time, because the Deep Neural Networks are being rebuilt.
Note
Changing the server name after installing the BriefCam software will require additional changes. If you need to change the server name, contact BriefCam Support.
