Alarms triggered by LPR
You can associate some types of alarms with events from XProtect LPR. Do the following:
  1. Create the match list (see Add new match lists) you want to match license plates against.
  2. Add and configure your LPR camera(s) (see Add LPR camera).
  3. In the Site Navigation pane > Alarms, right-click Alarm Definitions and select Add new to create a new alarm.
  4. The Alarm definition information window appears. Select the relevant properties (see Alarm definitions for LPR).
  5. Save your changes.
  6. Configure the alarm data settings for LPR (see Alarm data settings for LPR).
