Match lists
Match lists
A match list is a collection of license plate registration numbers and license plate style aliases (aliases) that you want your system to treat in a special way.
License plate recognitions are compared with these lists and if there is a match, the system triggers an LPR event. LPR events are stored on the event server. Operators can search for and view LPR events on the LPR tab in XProtect Smart Client. By default, LPR events are stored for 24 hours.
To change the event retention time:
In the Management Client, select Tools > Options > Alarms and events.
In Event retention > Retention time (days), change the retention time.
For each match list that you create, you can define events and alarms that triggers where there is a match.
Examples:
- A company headquarter uses a list of executive management's company car license plates to grant executives access to a separate parking area. When executives' license plates are recognized, the LPR solution triggers an output signal that opens the gate to the parking area.
- A chain of gas stations creates a list of license plates from vehicles that have previously left gas stations without paying for their gas. When such license plates are recognized, LPR triggers output signals that activate an alarm and temporarily block the gas supply to certain gas pumps.
You can also use triggered events to force cameras to record in high quality or similar. You can even use an event to trigger combinations of such actions.
Unlisted license plates list
Often you trigger an event when a license plate that is included in a match list is recognized, but you can also trigger an event with a license plate which is not included in a match list.
Example: A private car park uses a list of license plates to grant residents' vehicles access to the car park. If a vehicle with a license plate that is not in the list approaches the car park, the LPR solution triggers an output signal which lights a sign telling the driver to obtain a temporary guest pass from the security office.
To trigger a surveillance system event when a license plate that is not on any of your match lists is recognized, use the Unlisted license plates list. You select it for a camera like any other list (see Match lists tab) and set it up like any other list (see LPR에 의해 트리거되는 이벤트).
Add new match lists
- In the Site Navigation pane, select Match lists, right-click and select Add New.
- In the window that appears, give the list a name and click OK.
The newly created match list now appears in the Match lists window and on the Match lists tab of every LPR camera.
- To add columns to the match list, click Custom field and specify the columns in the window that opens (see Edit custom fields properties). You can add a maximum of five (5) columns.
- To update the match list, use the Add or Delete buttons (see Add match list items).
- Confirm your changes to save.
Instead of defining the match list directly in the Management Client, you can instead import a file (see Import and export match lists).
You can only edit the properties of custom fields.
자동차번호판 일치 목록은 등록 번호, 자동차 번호판 형식 별칭 및 차량 속성을 지원하지만 개별 자동차 번호판 형식은 지원하지 않습니다. 자동차번호판 일치 목록에 특정 자동차 번호판 형식을 포함하려면 먼저 자동차 번호판 형식 별칭을 만듭니다. 그런 다음 해당 자동차 번호판 형식 별칭을 목록에 추가합니다. Group license plate styles into aliases을(를) 참조하십시오.
- In the Site Navigation pane > Servers, select Match lists.
- 개요 창으로 이동합니다. Select the relevant match list.
- The Match list information window opens.
- To include new rows to your list, click Add and fill out the fields.
- Do not include any spaces.
- Always use capital letters.
Examples: ABC123 (correct), ABC 123 (incorrect), abc123 (incorrect)
- You can use wildcards in your match lists by defining plates with a number of ?'s and the letter(s) and/or number(s) which must appear at specific places.
Examples: ?????A, A?????, ???1??, 22??33, A?B?C? or similar
You can only import and export license plate registration numbers. Other vehicle information supported by match lists, for example aliases, cannot be imported or exported.
You can import a .csv or a .txt file with a list of license plate registration numbers that you want to use in a match list. You have the following import options:
- Add license plate registration numbers to the existing match list
- Replace the existing match list
This is useful if, for example, the match lists are managed from a central location. Then all local installations can be updated by distributing a file.
Similarly, you can export the complete list of license plate registration numbers from a match list to an external location.
To import:
- In the Site Navigation pane > Servers > Match lists, select the relevant match list.
- Select Import.
- In the dialog box, specify the location of the import file and the import type. Select Next.
- Await the confirmation and select Close.
To export:
- Select Export.
- In the dialog box, specify the location of the export file and select Next.
- Select Close.
- You can open and edit the exported file in, for example, Microsoft Excel.
Imports of a match list overwrites the current match list
"Exporting only export the registration numbers and not the aliases"
Match list properties
Name |
Description |
List name |
Shows the name of the list. If needed, you can change the name. |
Custom fields |
Select to specify which license plate entry columns that you or the client user can add additional information to. See Add match list items. |
Search |
Search the match list for any list item. If needed, you can use ? as a single wildcard |
Add |
Select to add a license plate registration number or an alias to the match list. When you're adding license plate registration numbers:
Examples: ?????A, A?????, ???1??, 22??33, A?B?C? and similar. Some regional areas might have exceptions to these rules. For example, personalized plates with spaces. Plates with two sets of characters which must be recognized separately by an underscore character ( _ ). Or plates from certain regions with letters on a different background color on parts of the license plate. Example: |
Edit | Make edits to properties of custom fields. |
Delete |
Click to delete the selected license plate number. |
Import |
Click to import license plate registration numbers from any comma-separated file, for example a .txt-file or .csv-file (see Import and export match lists). |
Export |
Click to export the list of license plate registration numbers to a comma-separated file, for example a .txt-file or .csv-file (see Match list properties). |
Rows per page |
Select how many list items to display in one page (one screen). You can choose between 50 and 1000 rows. |
Events triggered by list match |
Select which event(s) should be triggered by a list match (see Match list properties). You can choose between all available types of events defined in your system. |
You can add a maximum of five (5) columns to your match lists for additional information. You can define the name and number of columns, and the content of the fields.
XProtect Smart Client users can update the information in the columns but not the columns themselves.
Name |
Description |
Add |
Adds a column to the match list. Enter a name for the column. |
Edit |
Click to edit the name of the column. |
Delete |
Deletes a column. |
Up |
Changes the order of the columns. |
Down |
