Add an event for a device
  1. In the Overview pane, select a device.
  2. Select the Events tab and click Add. This opens the Select Driver Event window.
  3. Select an event. You can only select one event at a time.
  4. If you want to see an entire list of all events, allowing you to add events that have already been added, select Show already added events.
  5. Click OK.
  6. In the toolbar, click Save.
