Export storyboards
You can create a storyboard by pasting together video sequences into one cohesive flow and then export it.
In playback mode, start by opening a view that contains items that you want to add to your storyboard.
In the timeline, click
Select the start time and the end time for the storyboard.
For each item in the view that you want to add, select the corresponding check box
and click Export > Add to export list.Repeat steps 1-4 until you have added all items that you need for your storyboard.
Continue with the export process. See Adjusting export settings and Create an export.
