Add a carousel to a view
A carousel view item shows live video from each camera in a camera group in rotation so you’re aware of what is happening in your area.
  1. Select the view.
  2. On the workspace toolbar, select Setup.
  3. On the System overview pane, drag the Carousel item to a view item.
  4. In the Carousel setup window, under Cameras, double-click each camera to add to the carousel.
  5. In the Selected cameras list, arrange the cameras to define the sequence.
  6. Enter the display duration for the cameras in the carousel. You can specify a value for all or for each camera.
  7. (optional) Adjust the carousel’s settings on the Properties pane under Carousel setup.
    The Live stream setting on the Properties pane apply to all cameras in the carousel.
  8. Select Setup again to exit setup mode and save your changes.
