Add a camera to a view
To view video from a camera, you must first add the camera to a view.
  1. On the workspace toolbar, select Setup.
  2. Select the view.
  3. On the System overview pane, select a server and expand the folders to find the relevant cameras.
    If a server has a red icon, it is unavailable, and its cameras are not listed.
  4. Select a camera and drag it to a view item, or select a folder to add all cameras within it to your view.
    Check permissions for shared views: Ensure that users have permission to view video from the cameras in your shared view. If in doubt, contact your system administrator.
  5. On the Properties pane, specify camera properties (for example, live stream and PTZ click mode). See The camera settings (Properties pane).
  6. Select Setup again to exit setup mode and save your changes.
