Configuration Reports (System Dashboard node)
You make many choices when you install and configure your VMS system, and you may need to document these. Over time it is also hard to remember all the settings you have changed since the installation and initial configuration - or just during the last couple of months. That is why it is possible to print a report with all your configuration choices.
The following settings are available when creating and printing configuration reports:
                                             Name  |
                                             Description  |
| Reports | A list of elements that is possible to include in a configuration report. |
| Select All | Adds all elements in the Reports list to the configuration report. |
| Clear All | Removes all elements in the Reports list from the configuration report. |
| Front Page | Customize the front page of the report. |
| Formatting | Format the report. |
| Exclude sensitive data |
                                             Removes personal data like user names, e-mail addresses, and other types of sensitive data from the configuration report and makes it GDPR compliant. Information about the license owner is always exclude from the report.  |
| Export | Select a save location for the report and create it as a PDF. |
