Print a report with your system configuration
You make many choices when you install and configure your VMS system, and you may need to document these. Over time it is also hard to remember all the settings you have changed since the installation and initial configuration - or just during the last couple of months. That is why it is possible to print a report with all your configuration choices.
When you create a configuration report (PDF format), you can add any possible elements of your system to the report. You can, for example, include licenses, device configuration, alarm configuration, and much more. You can select the Exclude sensitive data option to create a GDPR compliant report (enabled by default). You can also customize the font, the page setup, and the front page.
- Expand System Dashboard and select Configuration Reports.
 - Select the elements that you want to include or exclude in your report.
 - Optional: If you have selected to include a frontpage, select Front Page to customize the information on your front page. In the window that appears, fill in the needed info.
 - Select Formatting to customize your font, page size, and margins. In the window that appears, select the wanted settings.
 - When you are ready to export, select Export and select a name and save location for your report.
Only users with administrator permissions in the VMS system can create configuration reports.
