Specify common properties for all devices in a device group
With device groups, you can specify common properties for all devices within a given device group:
- In the Overview pane, click the device group.
In the Properties pane, all properties which are available on all of the device group's devices are listed and grouped on tabs.
 - Specify the relevant common properties.
On the Settings tab, you can switch between settings for all devices and settings for individual devices.
 - In the toolbar, click Save. The settings are saved on the individual devices, not in the device group.
Disabled devices
All devices, including disabled devices, are by default displayed in the Overview pane.
To hide disabled devices, in the top of the Overview pane, click Filter to open the Filter tab and select Hide disabled devices.
To display disabled devices again, clear Hide disabled devices.
