Enable/disable devices via device groups
You can enable/disable devices only via the configured hardware. Unless manually enabled/disabled in the add hardware wizard, camera devices are by default enabled and all other devices are by default disabled.
All devices, including disabled devices, are by default displayed in the Overview pane.
To hide disabled devices, in the top of the Overview pane, click Filter to open the Filter tab and select Hide disabled devices.
To display disabled devices again, clear Hide disabled devices.
To locate a device via the device groups to enable or disable:
- In the Site Navigation pane, select the device.
 - In the Overview pane expand the relevant group and find the device.
 - Right-click the device, and select Go To Hardware.
 - Click the plus node to see all devices on the hardware.
 - Right-click the device you want to enable/disable, and select Enabled.
