Edit or delete link on smart map
Once you have added a link on your smart map, you can edit or delete it.
Steps:
  1. On the workspace toolbar, select Setup.
  2. To edit the link, right-click the link and select Edit link.
  3. To delete the link, do one of the following:
    • Right-click the link and select Delete link
    • Select the link and press DELETE on your keyboard
