Add link to smart map location or map
Adding links to your smart map lets you quickly visit locations, or display another type of map without changing to another view.
Steps:
- Select the view that contains the smart map, and then click Setup.
- Go to the point on the map where you want to add the link.
- In the map toolbar, click
Add a link, and then click the point on the map where you want the link to be.
- Specify whether you want to link to a smart map location, or a map, and then click Add.
Enter a name for the link.
You can display the title of the link on the smart map if you select Icon and text as the display style. Typically, names indicate where the link takes you.
- In the Destination field, select the map or location that the link goes to.
- In the Display style field, specify whether to display the name and link icon, or only the link icon on the map.
- Optional: Click Color to specify a color for your link.
