Make areas in shapefiles more visible (smart map)
This topic is relevant only if you are using shapefiles with polygons.
If you want to use a shapefile on your smart map that consists of polygons in close proximity, you may need to distinguish the individual polygons from each other. You do that by decreasing the opacity of the color you pick for the shapefile. The borders of the polygons will stand out.
- Follow the steps described in Add custom overlay on smart map.
When selecting the color, drag the Opacity slider to the left until you are ok with the level of transparency.
- Click Save.
