Add locations to custom overlays (smart map)
You can configure XProtect Smart Client to automatically add locations to custom overlaysClosedA user-defined, graphic element that users can add to a smart map, for example to illustrate a floor plan in a building, or to mark borders between regions. A custom overlay can be an image, a CAD drawing, or a shapefile. on your smart map. This allows you to jump to the custom overlays through the Select a location list.
Steps:
  1. On the global toolbar, select Settings and more and then Settings .
  2. Go to the Smart map tab.
  3. In the Create location when layer is added list, select Yes.
  4. Close the dialog to save the changes.
For more information, see Custom overlays and locations.
