Add buildings to smart map
Instead of using images or shapefiles to illustrate buildings, you can add an outline of a building. Afterwards, you can change the dimensions, angles, and size to match the shape and position of the actual building.
Smart map editing has been enabled on your Smart Client profile in XProtect Management Client.
Steps:
- On the workspace toolbar, select Setup.
- Navigate to the place on the smart map, where you want to position the building.
- Click
and place the cursor in the relevant position on the smart map.
- Click again. A rectangle is added to the smart map. If zoomed out, the zoom level automatically increases.
- If necessary, use the corner handles to adjust the shape and position of the actual building.
- Select Setup again to exit setup mode and save your changes.
