XProtect LPR
A Milestone extension that is designed for recognizing license plates in cameras’ video feed.
If you have an LPR tab in XProtect Smart Client, you have access to features from the XProtect LPR extension.
On the LPR tab, you can investigate LPR
Short for "license plate recognition". events from all your LPR cameras and view the
associated video recordings and license plate recognition data. Keep match lists updated and create reports.
The tab includes an LPR event list and an LPR camera preview. In the preview, you can view video associated with LPR event details. Below the preview, information about the license plate appears together with details from the match list and the license plate style that it is associated with.
You can filter the event list according to the period, country module, LPR camera, match list, or license plate style. Use the Search registration number field to search for a particular license plate registration number. By default, this list shows LPR events from the last hour.
You can specify and export a report of relevant events as PDF.
You can make updates to the existing match lists by using the Match list function.
