Add or edit secure tunnel servers
Communication for Remote Connect Services takes place via secure tunnel servers (ST servers).
- Do one of the following:
- To add an ST server, right-click the Axis Secure Tunnel Servers top node, select Add Axis Secure Tunnel Server
- To edit an ST server, right-click it, select Edit Axis Secure Tunnel Server
- In the window that opens, fill in the relevant information.
- If you chose to use credentials when you installed the Axis One-Click Connection Component, select the Use credentials check box and fill in the same user name and password as used for the Axis One-Click Connection Component.
- Click OK.
