Home page overview
On the top menu bar, you can use these tabs to do the following:
Item in menu
What can I do with it?
Milestone logo
Click to return to the Home page of XProtect Web Client.
Views
Investigations
Actions
Activate actions, for example, to open doors (see Activate actions).
Alarms
View alarms from all cameras (see View alarms).
Bookmarks View the list of bookmarks (see Bookmarks (usage)).
User menu If you want to exit XProtect Web Client, click , then select Log out.
More menu
Click the More menu to:
  • Select Settings and customize XProtect Web Client (see Settings).
  • Select Learn and read more about XProtect Web Client.
The left pane is collapsible. To collapse the pane, click . You can also adjust the pane borders by dragging them to the left-hand or right-hand side.
In the pane, you can go to these pane sections to do the following:
Item in menu
Search for cameras and views
Find a folder, view, or camera. You can filter out the irrelevant items from the list of views. The relevant matches are highlighted (see Search for camera).
Views
View videos from one or multiple cameras in live or playback mode. The Views pane section has a Show / Hide option. The Private and Public folders contain lists with subfolders with views inside.
Cameras View videos from one camera in live or playback mode. The Cameras pane section has a Show / Hide option. The camera groups and the related devices are organized in lists with folders with cameras inside.
