Install the Milestone XProtect Processing Server Admin Plugin
Download and install a plug-in for XProtect Management Client to send and receive data between your XProtect VMS and IVA applications through Milestone AI Bridge.
You need only install the plug-in on the computers with XProtect Management Client from which you want to subscribe to analytics topics and manage other administrator tasks related to the Milestone AI Bridge and IVA applications integration.
To install:
Log into the computers with XProtect Management Client.
Exit XProtect Management Client if the application is running.
If a patch for your version of XProtect Management Client is required, install this first. See Install a patch for XProtect Management Client.
If your IVA applications provide an URL with for a web page and if the Microsoft Edge WebView2 application is not already installed on the computers with XProtect Management Client, download the installer from https://developer.microsoft.com/en-us/microsoft-edge/webview2/ and install it.
From https://download.milestonesys.com/aibridge/plugins/, select your version of Milestone AI Bridge and then select the VideoOS.ProcessingServer.Plugin.Admin.Installer.exe file to download it.
Run the downloaded VideoOS.ProcessingServer.Plugin.Admin.Installer.exe file and follow the installation wizard.
When you re-start XProtect Management Client, a new node in the Site Navigation called Processing Servers is available. If you select Recording Servers from the Site Navigation and then select a camera, there is also a new Processing server tab.
You can configure and manage the behavior of your Milestone AI Bridge and IVA application integration in your XProtect VMS from the Recording Servers node and the Processing server tab.
If you cannot see the Processing Servers node, see Why is the Processing Servers node not available?.
