Enable smart map editing
Operators can edit smart maps in XProtect Smart Client in setup mode only if editing is enabled in Management Client. If not already enabled, you need to enable editing for each relevant Smart Client profile.
Steps:
  1. In the Site Navigation pane, expand the Client node.
  2. Click Smart Client Profiles.
    Client profile settings in the Setup tab.
  3. In the overview pane, select the relevant Smart Client profile.
  4. In the Properties pane, click the Setup tab.
  5. In the Edit smart map list, select Available.
  6. Repeat these steps for each relevant Smart Client profile.
  7. Save your changes. Next time users assigned to the Smart Client profile you selected log into XProtect Smart Client, they will be able to edit smart maps.
To disable editing, in Edit smart map list, select Unavailable.
