Specify an end position when patrolling
You can specify that the camera should move to a specific preset position when patrolling according to the selected patrolling profile ends.
- In the Site Navigation pane, select Devices and then select Cameras.
- Select the relevant PTZ camera in the Overview pane.
- On the Patrolling tab, in the Profile list, select the relevant patrolling profile.
- Select the Go to specific position on finish check box. This opens the Select preset dialog box.
- Select the end position, and click OK.
- The selected end position is added to the profile list.
You can select any of the camera's preset positions as the end position, you are not limited to the preset positions used in the patrolling profile.
When patrolling according to the selected patrolling profile ends, the camera moves to the specified end position.
