Prevent operators from switching between simple and advanced mode
In XProtect Smart Client, operators can switch between simple and advanced mode. However, you can prevent the XProtect Smart Client operators from switching between modes. Technically, you must lock the setting that determines whether XProtect Smart Client opens in simple mode or advanced mode.
- In Management Client, expand the Client node.
- Select the relevant Smart Client profile.
- Click the General tab.
- Verify that the Default Smart Client mode list has the proper value. If Enabled, XProtect Smart Client opens in simple mode.
- Select the Locked check box. The mode toggling button in XProtect Smart Client is hidden.
See also, Set simplified mode as the default mode.
