Getting started checklist
Follow the checklist to make sure that you carry out the steps of your XProtect BYOL deployment and configuration in the correct order. Each step is detailed in the later sections of this guide.
AWS deployment prerequisites
  • Have an AWS account
  • Have a key pair
XProtect VMS prerequisites
  • Obtain your software license (.lic) file and register your XProtect Software License Code (SLC)
  • Optional: Prepare a name for the EC2 instance
  • Make sure your camera models and firmware are supported by the XProtect system
  • Assign static IP addresses or make DHCP reservations to all cameras and devices
  • Network bandwidth consumption
  • Virus scanning (explained)
Configuration and deployment
  • Subscribe to XProtect BYOL in AWS Marketplace
  • Configure and deploy the XProtect BYOL CloudFormation template
Connecting to your deployment via RDP
Connecting your on-premises network
  • Configure AWS VPN end points
  • Configure site-to-site VPN end points
  • Configure on-premises VPN end points
  • Configure and join the on-premises domain
Adding your XProtect license
  • Add your XProtect product license
  • Activate your XProtect license
Securing your deployment
Scaling your system
Optimizing client access
