XProtect Web client
Cameras in your investigation area
Version2025r3
LanguageEnglish
When you view a group of cameras on the Views tab and then switch to the Investigations tab, the same group of cameras shows up in your investigation area.
Note
On the Investigations tab, you can only see the unique cameras in the view or group. The duplicate cameras do not show up in your investigation area.
Example:
  • You are in your Private folder on the Views tab. When you click the Investigations tab, all cameras in the Private folder show up in your investigation area.
To start playing incoming and outgoing audio in an investigation that you have created, you must:
