XProtect Transact for admins
Configuring transactions
Last Updated: 8 minute read
Version2026 R2
LanguageEnglish
After activating your XProtect Transact licenses:
  1. Add and configure the sources providing the transaction data, for example, the cash registers.
  2. Specify what defines a transaction, that is, where it begins and ends, including how it should be presented in XProtect Smart Client.
Note
When you are done setting up transactions, you can define transaction events and configure them to trigger rules or alarms. In XProtect Smart Client, operators can investigate transactions based on these events. For more information, see Configuring transaction events and alarms.
Add transaction source
To connect data from a transaction source to XProtect Transact, you need to add the sources of the transactions, for example, an automated teller machine. In the wizard, you select a connector, and you can connect one or more cameras.
Note
If you do not have a transaction source license for the transaction source you are about to add, the system will work during the 30-day grace period. Make sure that you acquire an additional transaction source license and activate it in due time.
Steps:
  1. In the Site Navigation pane, expand Transact.
  2. Go to the Overview pane. Right-click the Transaction sources node and select Add source. The wizard appears.
  3. Follow the steps in the wizard.
  4. Depending on the connector you select, different fields appear that you need to fill in. For more information, see Transaction sources (properties). You can change these settings after completing the wizard.
  5. If the transaction definition you need is not available, click Add new to create a new transaction definition.
The settings for transaction sources are described in the table.
Create and add transaction definitions
As part of defining a transaction source, you specify a definition for the source. A definition transforms the raw data received into presentable data, so that users can view the data in XProtect Smart Client in a format that matches real-life receipts. This is necessary, because typically the raw data consists of a single string of data, and it can be difficult to see where the individual transactions begin and end.
Steps:
  2. Select Transaction definitions.
  3. Go to the Overview pane.Right-click Transaction definition and select Add new. A number of settings appear in the Properties section.
  4. Use the Start pattern and Stop pattern fields to specify what data defines the start and end of a receipt.
  5. Click Start collecting data to collect raw data from the connected data source. The more data you collect, the smaller the risk of missing characters, for example, control characters, you want to replace or omit.
  6. In the Raw data section, highlight the characters you want to replace or omit. If you want to enter the characters manually, skip this step and click Add filter.
  7. Click Add filter to define how the selected characters from the transaction source data are displayed in XProtect Smart Client.
  8. For each filter, select an action to determine how the characters are transformed. The Preview section gives you a preview of how data is presented with the filters defined.
Note
You can also load previously collected data stored locally on your computer. To do this, click Load from file.
Transaction definitions (properties)
