XProtect System architecture guide
XProtect VMS products - System architecture
Version2026r2
LanguageEnglish
This guide contains illustrations and descriptions of communication and data flow between the most common system components in a distributed system. It covers a range of scenarios, each with a supporting illustration and description of actions, supplemented by information on port numbers, protocols, and bandwidth usage.
The illustrations are simplified and focus primarily on the general data flow between system components. This means that less important flows may have been omitted to reduce complexity.
