XProtect System architecture guide
Target audience and purpose
Version2026r2
LanguageEnglish
This guide is primarily aimed at system integrators and IT administrators. It gives insight on the benefits and simplicity of using Milestone XProtect as a VMS, and you can use it for assistance in the process of selecting, deploying, administering, maintaining, and expanding the Milestone XProtect VMS.
Read the guide for information about the following subjects:
  • Overall system architecture
  • Primary system components and their functions
  • Data flow and communication through the system
  • Basic system design
To benefit from the information in this guide, you should have a general experience with administering an IT installation.
