XProtect System architecture guide
Ports used by the system
Last Updated: 12 minute read
The XProtect VMS consists of server and client components that communicate over the network. This topic lists the ports required for each component and communication relationship.
You can look up ports in two ways:
  • By communication relationship — to see which ports are required between two parts of the system, for example between the management server and recording servers. This is the recommended approach when configuring a firewall.
  • By component — to see all ports used by a specific service. If you are used to looking up ports this way, expand the View by component section below.
Ports marked as local only do not require firewall rules.
Note
When certificates are installed, most HTTP communication switches to HTTPS, and TCP connections are secured with TLS. The port number does not change unless explicitly stated. Port 80 on the Management Server is a permanent exception — when certificates are installed, it provides access to well-known URLs only and remains open regardless of security mode. It is strongly recommended to restrict access to this port to internal management subnets only.
For CAPSS environments, Milestone recommends using HTTPS/TLS with certificates for all supported components and devices.
Port
Direction
Protocol (without certificates)
Protocol (with certificates)
Purpose
80
Both
HTTP
HTTP (permanent exception)
Always exposed on port 80 regardless of security mode. When certificates are installed, this port provides access to well-known URLs only.
Caution
It is strongly recommended to restrict access to port 80 to internal management subnets only.
443
Both
HTTPS
Web service when communication is secured with certificates.
9000
Inbound to Management Server
HTTP
HTTPS
Recording Server services. Web service for server-to-server communication.
9001, 9002, 9003…
Inbound to Recording Server
HTTP
HTTPS
Management server. Web service for server-to-server communication. Each additional Recording Server instance requires the next available port.
11000
Both
TCP
TCP (TLS)
Polling the state of recording servers.
These clients initiate outbound connections only to the following ports directly. All additional ports required by enabled server components and functionality are communicated to the client by the management server at login.
Port
Direction
Purpose
80
Outbound
HTTP
To and Management Server service. Authentication and access to APIs.
443
Outbound
HTTPS
7563
Outbound
TCP
TCP (TLS)
To Recording Server. Retrieving video, audio, and metadata streams, PTZ commands.
12345
Outbound
TCP
TCP (TLS)
To Management Server service. Communication between the system and Matrix recipients. You can change the port number in the Management Client.
22331
Outbound
TCP
TCP (TLS)
To Event Server service. Configuration, events, alarms, and map data.
22332
Outbound
WS
WSS
To Event Server service via Event/State Subscription, Events REST API, WebSockets Messaging API, and Alarms REST API.
Note
A 403 error will be returned when accessing HTTP to access an HTTPS-only endpoint.
Port
Direction
Purpose
8081
Outbound
HTTP
To XProtect Mobile server. Retrieving video and audio streams.
8082
Outbound
HTTPS
Port
Direction
Purpose
80
Outbound
HTTP
To XProtect Incident Manager via IIS.
443
Outbound
HTTPS
The Recording Server establishes outbound connections to cameras, NVRs, encoders, and other connected devices on the following ports. The port numbers listed are defaults — the actual port depends on the device configuration and may differ.
Port
Direction
Purpose
80
Outbound
HTTP
Cameras, NVRs, encoders, interconnected sites, and other connected devices. Authentication, configuration, data streams, video, and audio.
443
Outbound
HTTPS
Cameras, NVRs, encoders, and other connected devices. Authentication, configuration, data streams, video, and audio.
554
Outbound
Cameras, NVRs, encoders, and other connected devices. Data streams, video, audio, and other data.
7563
Outbound
TCP
TCP (TLS)
Interconnected sites. Data streams and events.
40001–40099
Outbound
HTTP
HTTPS
Mobile Server service. Video Push. This port range is disabled by default.
Port
Direction
Purpose
5210
Both
TCP
TCP (TLS)
Transfers recordings from a failover recording server back to the original recording server after it comes back online.
Also required to access archived video that was recorded before a camera was moved to a different recording server.
Caution
If this port is closed, that archived video will be inaccessible.
7563
Inbound to Failover Recording Server
TCP
TCP (TLS)
XProtect Smart Client. Retrieving video, audio, and metadata streams, PTZ commands.
8844
Both
UDP
UDP
Communication between Failover Recording Server services within a failover group.
8990
Inbound to Failover Server
HTTP
HTTPS
Management Server service. Monitoring the status of the Failover Server service.
9001
HTTP
HTTPS
11000
TCP
TCP (TLS)
Polling the state of recording servers between regular and failover servers.
8966
Inbound (local only)
TCP
TCP
Failover Recording Server Manager tray icon. Showing status and managing the service.
8967
TCP
TCP
Failover Server Manager tray icon. Showing status and managing the service.
Port
Direction
Purpose
7609
All servers
HTTP
HTTPS
Data Collector service on IIS. Collects and provides data for System Monitor.
Port
Direction
Purpose
80
Outbound from Event Server
HTTP
and the Management Server. Access the Configuration API.
443
HTTPS
Also sends status, events, and error messages to Milestone Customer Dashboard via https://service.milestonesys.com/.
1233
Inbound to Event Server
TCP
TCP
Listening for generic events from external systems or devices. Only if the relevant data source is enabled. Generic events are always unencrypted.
1234
TCP/UDP
TCP/UDP
1433
TCP
TCP
SQL Server
9090
TCP
TCP (TLS)
Listening for analytics events from external systems or devices. Only relevant if the Analytics Events feature is enabled.
22331
TCP
TCP (TLS)
XProtect Smart Client and the Management Client. Configuration, events, alarms, and map data.
22332
WS
WSS
and the Management Client. Event/State Subscription, Events REST API, WebSockets Messaging API, and Alarms REST API.
22333
TCP
TCP (TLS)
MIP plug-ins and applications. MIP messaging.
Note
MIP SDK plugins may dynamically require additional ports depending on the specific integration architecture. Refer to individual plugin documentation for details.
Port
Direction
Purpose
443
Outbound from API Gateway
HTTPS
Management Server. RESTful API.
22332
WS
WSS
Port
Direction
Purpose
554
Inbound
RTSP
RTSP
ONVIF clients. Streaming of requested video.
580
Inbound
TCP
TCP (TLS)
ONVIF clients. Authentication and requests for video stream configuration.
Port
Direction
Purpose
22334
Inbound to LPR Server
TCP
TCP (TLS)
Event server. Retrieving recognized license plates and server status. The Event server must have the LPR plug-in installed.
Note
Do not use these ports for other purposes even if your system does not apply SNMP.
Port
Direction
Purpose
7474
TCP
TCP
Windows SNMP service. Communication with the SNMP extension agent on the Failover Recording Server service.
12974
TCP
TCP
Windows SNMP service. Communication with the SNMP extension agent on the Management Server service.
12975
TCP
TCP
Windows SNMP service. Communication with the SNMP extension agent on the Recording Server service.
Port
Direction
Purpose
40001–40099
Both
HTTP
HTTPS
Mobile Server service and Recording server service. Video Push. This port range is disabled by default.
Port
Direction
Purpose
443
Outbound from Management Server
HTTPS
HTTPS
Milestone license server. Required for online license activation only.
Each section below covers all ports used by a specific service, giving you a complete picture of that component's network requirements.
Port
Direction
Purpose
80
Inbound
HTTP
All servers and the XProtect Smart Client and the Management Client. Always exposed on port 80 regardless of security mode. When certificates are installed, this port provides access to well-known URLs only.
Caution
443
Inbound
HTTPS
All servers and the XProtect Smart Client and the Management Client. Used when communication is secured with certificates.
445
Inbound
TCP
TCP
Management Server Manager. Enable Windows Active Directory users to be added to roles.
1433
Outbound
TCP
TCP
SQL Server.
443
Outbound
HTTPS
HTTPS
Milestone license server. Required for online license activation.
7609
All servers
HTTP
HTTPS
9000
Inbound
HTTP
HTTPS
12345
Inbound
TCP
TCP (TLS)
XProtect Smart Client. Communication between the system and Matrix recipients. You can change the port number in the Management Client.
12974
Inbound
TCP
TCP
Windows SNMP service. Communication with the SNMP extension agent. Do not use this port for other purposes even if your system does not apply SNMP.
6473
TCP
TCP
Management Server Manager tray icon. Showing status and managing the service.
8080
TCP
TCP
Communication between internal processes on the server.
Port
Direction
Purpose
80
Outbound
HTTP
443
Outbound
HTTPS
554
Outbound
5210
Inbound
TCP
TCP (TLS)
Failover recording servers. Transfers recordings from a failover recording server back to the original recording server after it comes back online. Also required to access archived video recorded before a camera was moved to a different recording server.
Caution
7563
Inbound
TCP
TCP (TLS)
XProtect Smart Client, Management Client. Retrieving video, audio, and metadata streams, PTZ commands.
7563
Outbound
TCP
TCP (TLS)
9001, 9002, 9003…
Inbound
HTTP
HTTPS
11000
Inbound
TCP
TCP (TLS)
Failover recording servers. Polling the state of recording servers.
12975
Inbound
TCP
TCP
40001–40099
Outbound
HTTP
HTTPS
8966
TCP
TCP
65101
UDP
UDP
Listening for event notifications from the drivers.
Port
Direction
Purpose
80
Outbound
HTTP
443
Outbound
HTTPS
1233
Inbound
TCP
TCP
Generic events from external systems or devices. Only if the relevant data source is enabled. Generic events are always unencrypted.
1234
Inbound
TCP/UDP
TCP/UDP
1433
Outbound
TCP
TCP
SQL Server.
9090
Inbound
TCP
TCP (TLS)
Analytics events from external systems or devices. Only relevant if the Analytics Events feature is enabled.
22331
Inbound
TCP
TCP (TLS)
22332
Inbound
WS
WSS
22333
Inbound
TCP
TCP (TLS)
Note
Port
Direction
Purpose
8000
TCP
TCP
Mobile Server Manager tray icon. Status and service management.
8081
Inbound
HTTP
Mobile clients, Web clients, and Management Client. Sending data streams; video and audio.
8082
Inbound
HTTPS
Mobile clients and Web clients. Sending data streams; video and audio.
40001–40099
Inbound
HTTP
HTTPS
Port
Direction
Purpose
5210
Inbound
TCP
TCP (TLS)
Caution
7474
Inbound
TCP
TCP
7563
Inbound
TCP
TCP (TLS)
8844
Inbound
UDP
UDP
Communication between failover recording server services.
8966
TCP
TCP
8967
TCP
TCP
8990
Inbound
HTTP
HTTPS
9001
Inbound
HTTP
HTTPS
11000
Outbound
TCP
TCP (TLS)
Port
Direction
Purpose
80
Inbound
HTTP
IIS. XProtect Smart Client and the Management Client. Used when communication is not secured with certificates.
443
Inbound
HTTPS
IIS. XProtect Smart Client and the Management Client. Used when communication is secured with certificates.
