XProtect Smart Wall for users
Configuring XProtect Smart Wall
Version2026 R2
LanguageEnglish
After doing the initial configuration in XProtect Management Client, operators can start using the video wall by sending the Smart Wall monitors onto the physical monitors connected to the system. This may include one or both of these options:
  • Static views
  • Views that change dynamically based on rules
Additional configuration is necessary if you want to:
  • Enable operators to control and manually change what is being displayed on the physical monitors. In that case, you must add the Smart Wall control to designated views.
  • Change the existing view layout of individual monitors.
  • Reset or change the preset already applied to the Smart Wall definition.
Add Smart Wall controls to views
Change view layout of Smart Wall monitors
Reset or change Smart Wall presets
