Verify a Smart Client script
Version2026 R2
LanguageEnglish
You can verify a Smart Client script (.scs) before deploying it to confirm that the script file is valid, uses supported syntax/actions, and runs without errors.
Prerequisites
  • An .scs script file stored on a local or accessible network drive.
Steps
  1. In XProtect Smart Client, on the global toolbar, select Settings and more SC_GlobalToolbar_SettingsAndMore_icon.jpg and then Settings.
  2. Select the Scripts tab.
  3. Select Verify script….
  4. In the file browser, select the .scs file you want to test, then select Open.
  5. Review the verification result displayed in the dialog:
    • If the script is valid, a confirmation message tells you it passed validation.
    • If the script contains errors, review the reported issues, such as unsupported commands, invalid XML formatting, or schema incompatibilities, before you run the script again.
