Panes settings
Version2026 R2
LanguageEnglish
The Panes settings let you specify whether you want a pane to appear on a particular tab.
Note
Some panes may contain functionality which may not be available to you, either because of your user permissions or the surveillance system you are connected to.
The Mode column displays where the pane is available, the Function column lists the name of the pane, and the Setting column lets you specify whether you want the pane to be available or unavailable.
If available, the Follow server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings may already be server-controlled, in which case configuration on the server decides whether you can override the settings.
