Application settings
Last Updated: 5 minute read
Version2026 R2
LanguageEnglish
Application settings let you customize the general behavior and look of your XProtect Smart Client.
If available, the Follow server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings are server-controlled, in which case, configuration on the server decides whether you can override the settings.
Name
Description
Application maximization
Specify how windows in XProtect Smart Client react when you click the Maximize button.
To avoid that the Windows taskbar is covered when you maximize a window, select Maximize as normal window.
Camera error messages
Specify how the XProtect Smart Client displays camera-related error messages. These can be displayed as an overlay on top of the camera image or on a black background, or hidden completely.
Server error messages
Specify how the XProtect Smart Client displays server-related message texts. These can be displayed as an overlay on top of the camera image or on a black background, or hidden completely.
Live video stopped message
Specify if the XProtect Smart Client displays a message when a camera is connected but the camera is not sending live video feed. The message can be displayed as an overlay on top of the camera image or on a black background, or hidden completely.
Default for camera title bar
Select whether to show or hide the camera title bar. The title bar displays the name of the camera and the colored indicators signifying events, detected motion, and video recordings.
Note
You can override this setting on individual cameras by adjusting camera properties for the camera(s) in setup mode.
Show current time in title bar
Specify whether to show or hide the current time and date (of the computer running the XProtect Smart Client) in the title bar.
Show in empty view positions
Specify what to show if there are empty view items in views, for example, you can select a logo or have just a black background displayed.
View grid spacer
Specify the thickness of the border between view items in views.
Default image quality
Important
Specifying a default quality of video viewed in XProtect Smart Client is only relevant if you are viewing JPEG streams. If you are viewing other codecs like H264 and H265 and reduce the quality, you will increase the bandwith, CPU, and GPU usage when re-coding to JPEG.
Note that image quality also affects bandwidth usage. If your XProtect Smart Client is used over the internet, over a slow network connection, or if for other reasons you need to limit bandwidth use, image quality can be reduced on the server by selecting Low or Medium.
Note
Default frame rate
Select a default frame rate for video viewed in the XProtect Smart Client.
Note
Default video buffer
If you require very smooth display of live video, without any jitter, it is possible to specify a video buffer.
Note
Video buffering can significantly increase memory usage for each camera displayed in a view. If you do need to use video buffering, keep the buffering level as low as possible.
Default PTZ click mode
Specify a default PTZ click mode for your PTZ cameras. Options are click-to-center or virtual joystick. You can override this setting on individual cameras by selecting a different default PTZ click mode for the camera.
Start mode of main window
Specify in which screen mode the main window of XProtect Smart Client opens after you have logged in. Options are Full screen, Maximized, Window and Last.
Restore windows and tabs
Specify whether you want to restore the windows and tabs left open when you last logged out of XProtect Smart Client. Options are:
Hide mouse pointer
Specify whether you want the mouse pointer to be hidden after a period of inactivity. You can specify how much time you want to elapse before hiding the mouse pointer. The default option is after 5 seconds. Options are:
  • Never
  • After 5 seconds
  • After 10 seconds
  • After 20 seconds
  • After 30 seconds
If you move the mouse after a period of inactivity, it is enabled immediately.
Snapshot
Take a snapshot to share.
Path to snapshots
Specify the path indicating where you want your snapshots to be saved to.
Help
Choose whether to make help available in XProtect Smart Client. If you disable it, pressing F1 won't do anything, context-sensitive links will disappear, and you won't be able to access help from the Settings and more menu.
Timestamp on snapshot
Choose to show or hide timestamps on snapshots. If you choose Show, the timestamps also appear on printed and copied snapshots.
Camera name on snapshot
Choose to show or hide camera names on snapshots. If you choose Show, the camera names also appear on printed and copied snapshots.
Video tutorials
Specify whether the user should be able to access video tutorials for XProtect products from the Settings and more menu.
