Open a view and maximize a view item
Version2026 R2
LanguageEnglish
To view live or recorded video, you select a view that contains the relevant video.
  1. Select the main views tab.
  2. On the Views pane, select the view containing the relevant video.
    Alternatively, if the view has a shortcut number, you can select the view with * + [shortcut number] + Enter on the numeric keypad. For example, to select a view with shortcut number 1, press * + 1 + Enter.
  3. To maximize a view item to see the details in the content of the view item, select the view item and double-click or press Enter. To minimize, double-click or press Enter again.
See Default keyboard shortcuts and Assign a shortcut number to a view.
