Enable or disable access to the user assistance
Version2026 R2
LanguageEnglish
If your system administrator has given you permission, you can enable or disable direct access to the user assistance in XProtect Smart Client.
  1. Open the Settings window in XProtect Smart Client.
  2. From the Application tab and in the Help list, select one of the following options:
    • Unavailable to disable the user assistance.
      When you press F1, nothing happens. Context-sensitive links and Help buttons within XProtect Smart Client are no longer visible.
    • Available to enable the user assistance.
      When you press F1, the relevant topic in the XProtect Smart Client user assistance is opened. Context-sensitive links and Help buttons are available.
