[en] Issue: Commands that alter the window or views seem delayed
Version2026 R2
SprogDansk
[en] Cause
[en] In Smart Client scripts, the <Script> body executes only after the login process has completed and the main workspace has fully rendered.
[en] Commands such as SCS.Application.Minimize(); or view selections do not run during the startup phase. As a result, the main window briefly displays on screen before it minimizes or switches views.
[en] Solution
[en] This is expected behavior. If your deployment requires specific default views on launch, consider configuring the Application start view in Smart Client settings alongside your script.
