[en] Verify a Smart Client script
Версия2026 R2
ЕзикБългарски
[en] You can verify a Smart Client script (.scs) before deploying it to confirm that the script file is valid, uses supported syntax/actions, and runs without errors.
[en] Prerequisites
  • [en] An .scs script file stored on a local or accessible network drive.
[en] Steps
  1. [en] In XProtect Smart Client, on the global toolbar, select Settings and more SC_GlobalToolbar_SettingsAndMore_icon.jpg and then Settings.
  2. [en] Select the Scripts tab.
  3. [en] Select Verify script….
  4. [en] In the file browser, select the .scs file you want to test, then select Open.
  5. [en] Review the verification result displayed in the dialog:
    • [en] If the script is valid, a confirmation message tells you it passed validation.
    • [en] If the script contains errors, review the reported issues, such as unsupported commands, invalid XML formatting, or schema incompatibilities, before you run the script again.
