[en] Issue: The startup script couldn’t be run without errors.
Последно актуализиране: 3 минути четене
Версия2026 R2
ЕзикБългарски
[en] Error message: “The startup script '<script_name>' couldn't be run without errors. Check the application logs for details or contact your system administrator.”
[en] Cause
[en] When XProtect Smart Client launches with a startup script (.scs), Smart Client scripts engine validates the script contents. If the script contains errors or unvalidated commands, the engine blocks it for security reasons and displays this notification in the global banner.
[en] Solution
