View video in carousel view items
In live mode, a carousel view item rotates between camera feeds at defined intervals. Carousel view times enables you to patrol and be aware of what is happening in areas of interest.
The timing of the carousel begins when you open the view. So, if you have two views with the same carousel view item open, you’re watching two separate timings of the same carousel.
Tip
You can recognize a carousel view item by the
icon in the title bar.
Open a view that contains a carousel.
Do one of the following actions:
To continue to view the same video in the view item, on the camera toolbar, select Start / stop carousel
. Select Start / stop carousel
again to start the carousel.Note
If you zoom in on the video in a carousel view item, the carousel automatically stops.
To show video from the next or previous camera in the carousel view item, select Previous camera
or Next camera
